Help! For the first time I have removed my Numark and plugged in the RMX to my amp and I'm getting what sounds like
digital communication signal bleeding across the speakers.
I have trued all I can and I'm about to chuck this thing out the window. Any help would be great.
Thanks
Thanks
Posted Sun 21 Mar 10 @ 4:46 pm
Try unplugging your laptop. If the sound stops, you've got a ground loop issue. Get one of those little adapters that takes a 3-prong power plug and makes it a 2-prong.
Posted Sun 21 Mar 10 @ 5:17 pm
Brother I thank you. Every item on my system is grounded. I pulled the 3rd pole off the power supply and its gone.
Big thanks for the help.
Posted Sun 21 Mar 10 @ 5:29 pm
