Virtual DJ auto gain is set to...Auto+Remember...
When I use the internal soundcard from my laptop and use automix for example, dinner music, the output volume is always stable at the same level.
When I use my xponent on the same laptop in the same scenario the output volume is the same as my 1st scenario.
Problem - When I use my NS7 the volume for one song will be different from the next one. It may play 5-6 songs and then the next song will be very loud or too low. All the configuration settings are the same, I only change the soundcard/controller.
What can cause the NS7 to be different? It's a pain because at my functions I go out in the crowd to animate and it's embarressing to have to run back quickly through the crowd to lower the volume or have to turn it up and then go back into the crowd to finish what I was doing.
Posted Wed 17 Mar 10 @ 12:02 am
same settings and same things happen when I use vdj with my RMX. Is there any fix?
Posted Wed 17 Mar 10 @ 1:35 am
try changiing the setting to "Remember" maybe that will work
Posted Wed 17 Mar 10 @ 2:36 am
I'll try that tonight but I think I already tried it... Strange that it happens to only certain controllers/soundcards
Posted Wed 17 Mar 10 @ 8:52 am
Same outcome... Anymore ideas?
Posted Fri 19 Mar 10 @ 7:46 pm
I'll like to know the same also.
Posted Fri 19 Mar 10 @ 9:18 pm
