Hi Guys,
Can someone help me find the discussion post for how to troubleshoot Timecode Vinyl? I know there were discussion post about it but I can't find any specific ones that has a solution remove the high pitch sounds from the speakers. I'm not sure if that is something that can be removed or not. I have a gig on Saturday and I want to utilize the timecode vinyls
Posted Tue 16 Mar 10 @ 11:52 am
Make sure you're not monitoring the input channels for the timecode. For example if using a Maya44 there is an option in it's control panel for it. What soundcard are you using?
Posted Tue 16 Mar 10 @ 3:25 pm
I'm running off the Hercules RMX sound card. Also I'm using Virtual DJ on MAC OS (Snow Leopard) just to give specifics.
Posted Tue 16 Mar 10 @ 3:40 pm
I forgot to leave out that I use Serato Timecode Vinyls Version 2.
Posted Tue 16 Mar 10 @ 3:52 pm
I suspect it is a channel monitoring issue, but unfortunately I don't have the RMX and I dont use Mac. I'm sure someone else will be along to help though :)
Posted Tue 16 Mar 10 @ 6:24 pm
Does anyone have a Hercules RMX and runs serato timecode vinyls on a MAC OS? I'm trying to figure out how to remove high pitch sound coming out of the speakers.
Posted Wed 17 Mar 10 @ 6:30 pm
sounds like u need to change ur phono/stereo settings, the high pitched tone is the timecode signal. u would here that if u have it in the thru settings.
Posted Fri 19 Mar 10 @ 4:33 pm
Try your source 1 and 2 button on the RMX.
Posted Fri 19 Mar 10 @ 7:11 pm
Thanks, I was having the same problem & this helped me. Was about to go nuts, the sound was driving me crazy. Couldn't figure it out for the Life of me... Thanks again.
Posted Tue 08 Jun 10 @ 8:29 pm
having the same problem, im using numark omni control, the high pitch sound usually come in when load track on the cueing deck.. it also come in suddenly in the middle of the track or somewhere else.. im having a headached here.. whew!
Posted Thu 16 Sep 10 @ 12:31 pm
check out my collection ;-D:
http://www.facebook.com/album.php?aid=3709&id=100001107366596&l=07b8fe2b9c
Posted Thu 16 Sep 10 @ 6:02 pm
