in brief
i got 2 cdj 1000mk3
djm 800
laptop + virtual dj
hercules rmx (as the soundcard for useing timecodes)
so if i set this up and conect djm 800 to laptop via midi cable , and assaign coss fader.
so will i be able to use djm's built in effects and color fx effects if i conect it to vdj ? or will they be unable andonly crossfader and volume controles will be available ?
i got 2 cdj 1000mk3
djm 800
laptop + virtual dj
Posted Fri 12 Mar 10 @ 12:48 pm
The effects built into the mixer are applied to the sound that's input into it, so yes, you will be able to them.
Posted Fri 12 Mar 10 @ 3:01 pm
