i use a Hercules Console Rmx with Virtual DJ pro 6. when im mixing i hear a fuzzing noise when i adjust the the Trebs, mids and bass
i there anything that i can do to stop it? i have a set this saturday on a 10 k rig and im worried that that buzzy/fuzzy noise is gonna sound very loud on that system.. is there anything i can do on config to sort this out?
please help.
many thanks DJ Justy
please help.
Posted Thu 11 Mar 10 @ 6:16 pm
Pls do not post the same issue on multiple forum as it may cause confusion.
You are on mac or pc?
Please use your initial thread on the mac forum for further communication.
https://virtualdj.com/forums/125522/MAC_Version_Technical_Support/Fuzzy_noise_when_using_the_equalisation_.html
Regards.
Thread lock.
Regards.
Thread lock.
Posted Fri 12 Mar 10 @ 2:00 am
