Hey Guys,
i have the following problem: The display Scolling is a little bit jerky. Who does not know what I mean, here's a short video:
http://www.youtube.com/watch?v=xeAvD4GGSiA
I use the Asio drivers and the best possible latency of 2ms. Use also currently 2 systems and both are equipped with Win 7 Pro and a lot of Ram. I have no music or other dropouts LAGS. this is extremely annoying.
Only this Problem occurs with the Console Rmx. At my old Control Mp3 e2 itself, everything went perfectly with ASIO4ALL!
Here are a few photos of my config:
http://www.flickr.com/photos/30313271@N02/4417302304/sizes/o/in/photostream/
http://www.flickr.com/photos/30313271@N02/4416536687/sizes/o/in/photostream/
http://www.flickr.com/photos/30313271@N02/4417302426/sizes/o/in/photostream/
http://www.flickr.com/photos/30313271@N02/4417302536/sizes/o/in/photostream/
http://www.flickr.com/photos/30313271@N02/4416536933/sizes/o/in/photostream/
Here are a couple of failed solutions: WDM enabled Asio latency increases (then still more jerky), reset everything ...
I am using Win 32-BIT 7 Pro with 4GB Ram and a Core2Duo @ 3GHz
The max. Utilization is 25% if a track is loaded.
Also, the change in the Display Driver to VSYNC -> ON makes no changes!
Thank you for your expertise already :-)
DaJay82
DaJay82
Posted Tue 09 Mar 10 @ 6:07 am
And this is with the latest update for VDJ (v5.2.2) ?
Have you tried maybe updating or making changes to the vide card driver ?
As for the MP3 e2, this is a completely different version of VDJ (based on version 6), so it's highly possible that improvements were made between the 2 versions.
Posted Tue 09 Mar 10 @ 8:06 am
I updated my video card drivers. Unfortunately, without success.
But I think it is a common problem with Windows 7 Pro. On my Lenovo laptop other components are installed and there is also the same problem.
I mean the Problem is the Asio 2.0 Driver for Windows 7...
I'm surprised only that others do not have this problem.
BIG THX
BIG THX
Posted Tue 09 Mar 10 @ 9:58 am
still having the problem? i am debating if i should upgrade to 7.
Posted Wed 24 Mar 10 @ 8:14 pm
