Hey there,
i would use my MAC Version .. but i wait form 6.0.2 to 6.0.7 and the Waveform is still hanging and do not run very well.
When i started my XP on Bootcamp, there is no hanging on the Waveform.
On my Windows 7 64 Bit PC is the same bug.
There are so many Mac-Users with VDJ and noone got this issue?
Regards Max
Regards Max
Posted Mon 08 Mar 10 @ 10:56 am
I'm a Mac user and I don't have this issue.
Posted Mon 08 Mar 10 @ 12:11 pm
no problems with the waveform here either.
Posted Mon 08 Mar 10 @ 12:50 pm
And wich MAC?
I got the Macbook Late 2009 (OCT2009) 4 GB RAM.
Hm ... what can i do ? ... I dont know any more way ... =(
Posted Mon 08 Mar 10 @ 3:32 pm
No problem here as well.
When you said hanging, is it for a second and jerky?
Posted Mon 08 Mar 10 @ 10:52 pm
no its just all the time.
There is one Video :
Look at the Waveform, this is my Problem. The Time and other things run with no hanging but the Waveform is hanging.
My Eyes get crunk with this .. =(
Max
Posted Tue 09 Mar 10 @ 2:46 pm
After looking at the video I noticed your CPU was running unusually high. It seemed to be hovering around 80-90% all the time. When I run VDJ it hovers around 15%. I think it may be a hardware issue.
Posted Tue 09 Mar 10 @ 6:37 pm
can you post a video with nothing playing?
try setting you performace all the way to the left, and put your latency on auto.
Posted Tue 09 Mar 10 @ 10:20 pm
I was messing around with my timecodes and the pitch sensitivity setting in the 'debug' sub-window of the timecode set up window, and I noticed that if you have the pitch sensitivity set too high it causes the waveform to be quite jerky. Try playing with that setting and see if it works.
Posted Wed 10 Mar 10 @ 9:18 am
The CPU is to high cuz its recording this Video.
The normal CPU usage is 20 %.
I found a Guy in the German Forum with the same Bug.
There is a better Video:
U see the Waveform is not normal... this is the Bug i mean.
I set Timecode off cuz i use the Vestax Vci 100 .. i try a lot of things .. but i dont know.
My Macbook got now 4 GB Ram ... and nothing is better.
@DJ Cyder
Hm a Video with the Decks stopped?
Or what u mean?
So on .. Max
Posted Wed 10 Mar 10 @ 11:56 am
