Topic: hercules dj console rmx
im getting the hercules dj console rmx this week.it comes with vdl 5.0.i recently tried 6.0.6 and rather use it(new years edition)would it work ? if not do i just update or upgrade.can some 1 help me out here.thanks
Posted Mon 08 Mar 10 @ 3:26 am
The Hercules RMX Mapper is included in the Virtual DJ PRO Version (6.0.7)
If you wanna buy the VDJ Pro Version you get an Discount.
https://virtualdj.com/buy/
go there and fill in your licence key from your Virtual DJ LE Version than you get the Price for that upgrade.
I think you will Love this unit. It works to the tee with VDJ I never had any trouble with the unit either. Good luck! Dj Double "A"
thanks 4 the info.
my laptop has dual core (2 ghz each) 320 gb hard drive 1 gb ram is that enought 2 run the hercules rmx smoothly(farely new laptop) thanks 4 any reply
should run ok.but i upgraded my ram to 4gb a year back and havent looked back.little tip though.go to hercules website there are tips there to help make your laptop dj friendly works a treat.
thanks
Don't forget it's essential to download the latest RMX drivers from the Hercules website. ;-)
I just Purchased My dj console Rmx about 9 days ago & have yet to get it running. I heard everyone talkin about how good it was & followed suit. Even purchased a new lap top to run it on. I've been on the phone with tech support for the last week or so & still nothing. I don"t know if it's the Windows 7 or what but I'm at wit's end plus the fact that I have over $1000 worth of usless equipment just sitting here collecting dust doesn't help either.
im sure the guys here can help u .where did u buy it from?
