Hi guys,
What would be the best operating system and what must be turned off within windows to make it faster to run properly for VDJ.
Windows 7 32
Windows 7 64
Windows XP
Windows 7 32
Windows 7 64
Windows XP
Posted Tue 23 Feb 10 @ 9:34 am
XP Professional 32 bit would be my OS of choice, however it seems to run fine in Windows 7 32 bit as well.
You can carry out optimisations if you want to but I've never bothered and VDJ works fine on both those operating systems.
I would avoid 64bit for the mo ..... 3gb RAM is more than enough anyway!
Posted Tue 23 Feb 10 @ 10:52 am
I'm running windows 7 32-bit. It's on a mac though, but is flawless.
Posted Tue 23 Feb 10 @ 4:27 pm
Even though windows 7 works, i still preffer Windows XP. Its compatable with all the drivers and the latency is very low. The lower the latency, the better the responce time.
Thanks Sischo..
Thanks Sischo..
Posted Tue 23 Feb 10 @ 5:11 pm
Latency ;)
Posted Tue 23 Feb 10 @ 5:15 pm
XP Pro is the go, as it is the most stable I've found for VDJ
Posted Wed 24 Feb 10 @ 2:48 am
I agree. Windows XP is my choice.
Regards Tjeck
Regards Tjeck
Posted Wed 24 Feb 10 @ 3:28 am
hello
I've been running it just fine on WIndows 7 Premium x64bit. Pretty stable with the optimizations, the longest session i did was a 5 hour Gig, and performed without any hiccups. If I decided to add WIndows XP. Would i get anymore Performance gains as far as latency that's mentioned above?? I'm using virtual DJ with Hercules rmx. On the herules rmx control panel, my Latency is set to 10ms, that's to stay on the safe side. and in the virtual DJ app, I tick off Safe and Overclock, left it on auto and the performance SLider is at the default position which is more near to fast performance. I notice alot of people with the hercules rmx set's the slider to fast, I did that, and didn't really notice much of a difference, so i put it back where it was, just to insure myself. If anyone has any suggesstions or using the hercules rmx stably at a lower latency, please share, thanks
Asus G51 (Best Buy Version)
COre2Duo 2.00GHZ
4GB RAM DDR2 800mhz
GeForce 260m GTX 1GB RAM
Came with Vista x64 originally, upgraded to Windows 7 64 bit Premium
COre2Duo 2.00GHZ
4GB RAM DDR2 800mhz
Posted Wed 24 Feb 10 @ 5:15 am
i run windows 7 64 with no real problems.
Posted Wed 24 Feb 10 @ 7:22 am
XP Pro all the way. I do videos at a local club quite regularly with no latency or lag whatsover using VDJ 6.0.3 and the K-lite codec pack
Posted Wed 24 Feb 10 @ 9:04 am
XP Pro; I can run VDJ LE for audio, Media Player Classic Homecinema for video and MS Powerpoint all at the same time with no issues.
My hardware is nothing special.
Posted Wed 24 Feb 10 @ 10:14 am
hiya ive put a particion on my laptop to run both xp & windows 7 ive got vdj 6.6 running on both operating systems & both work flawless the reason ive put xp on aswell is becouse my midi controler (bcd2000) as only got drivers for xp at moment ive got to say (believe me or not) the bcd2000 is working flawless with the 3.4 mappers only paid £30 for it off a freind love it. im getting myself a tower this week so i,ll be able to compare them soon
Posted Sun 28 Feb 10 @ 9:30 am
Drum roll please......Drrrrrrrrrrrrrrrrrrrrrrrrrr And the winner is........................ Windows XP
Posted Sun 28 Feb 10 @ 12:25 pm
hold thoe drums... i'm on Vista 32 bit. with no (serious) problems..
ok, bring on the drums...
XXX
XXX
Posted Sun 28 Feb 10 @ 12:40 pm
There is no "best" OS for using with VDJ. I use XP on one machine, and Vista64 bit on another, with no issues. The big thing is proper configuration of your PC. If it is a big box outlet PC the user is going to need to spend time deleting all the bloatware that came with it. If it is one custom made, there are often tweaks that are still needed to ensure maximum performance. That being said, XP does have the fastest usb speeds of all the windows OSs on the market at this time.
Posted Sun 28 Feb 10 @ 2:34 pm
Exactly Terry, Every person has their on experiences with operating systems.
Don't put me on the XP-Express. I had "issues" with XP.
After I updated to VISTA I've been crash free (using 99% video) since December 2008 with more than 1000 hours of "live performance" on the machine. My backup computer which I rotate in and out of service also runs VISTA with no issues. (I have Win-7 on my home computer and it's been NOTHING but a pain.
Posted Sun 28 Feb 10 @ 2:45 pm
I found Win Pro worked the best tbh
But i skipped vista and now have Windows 7 Ultimate 64 Bit.
Not one hic-up yet!
Not one hic-up yet!
Posted Mon 01 Mar 10 @ 2:37 pm
I agree with you mate!!!
I've used XP (32bit), Vista (32bit) and now 7 (32bit)
Out of the 3 I do prefer 7. I haven't had any problems with it since I installed it last November. Both my DJ software's run perfectly on Win 7!!!!
Posted Mon 01 Mar 10 @ 2:48 pm
I use win7 64 and it rocks!
Posted Mon 01 Mar 10 @ 3:17 pm
Someone is bound to say Mac?
Posted Mon 01 Mar 10 @ 3:22 pm
