I'm having problems trying to assign a button to trigger the loop_in on deck 1 with my Korg nano Kontrol. In the simple MIDI Wrapper I'm able to do the Key-Learn chose the button I want to assign which is 0-CC57, in the action I put in " deck 1 loop_in" . After closing the settings window and pushing the assigned button on the controller nothing happens. I'm able to click on it with the mouse and it works. When I hover over the button with the mouse pointer the help message pops up and shows me that the non Kontrol button is assign to it and the action is deck 1 loop_in.
Any help is appreciated.
I eventually want to control both deck loop functions with the nano controller.
Thanks for looking
Eric
Thanks for looking
Eric
Posted Sat 20 Feb 10 @ 1:15 am
Instead of mapping it manually with Simple MIDI - maybe you take a look to this predefined mapper ?
https://virtualdj.com/addons/10774/KORG_nanoKONTROL_Def___Mapper.html
Greets, Heiko
Greets, Heiko
Posted Sat 20 Feb 10 @ 4:54 am
