Need a basic karaoke player to run on xp. Just for playing tracks and ability to print tracklist. Its just for my dad to practise with at home so dont need vdj features. PC is XP notebook but fairly low spec - vid card not good enough to run vdj. Any suggestions?
Posted Thu 18 Feb 10 @ 4:59 pm
Mp3+G Toolz 4 and it's free http://www.activeaspsoftware.net/default.aspx?p=home
It installes as a shell tool, so all you have to do is right click over Karaoke Zip choose the Mp3 Toolz, then click the Play option and your done.
Good Luck
Joey.....
Good Luck
Joey.....
Posted Thu 18 Feb 10 @ 6:07 pm
Thanks for the suggestion but what I really need is a simple GUI. My father has pretty much no pc skills. To give you some idea - turned on his pc, he says how did you do that. Do what, I havent done anything yet. How did you move that arrow on the screen...
OK, so any suggestions for a good simple to use karaoke player with ability to print playlists that isnt resource hungry and doesnt cost tooo much.
Posted Fri 19 Feb 10 @ 2:51 pm
