say that the xfader is completely on deck B, if i play with deck A's turntable youll hear clipping noises or other weird sounds...even if A's volume is at 0.
how do i stop this from happening?
Posted Wed 17 Feb 10 @ 10:09 pm
Hi mate
Sounds like a latency issue. If you are playing with deck A and the fader is down it is still using processor time and can causenoises on the playing decks audio.
If you go to the config/performances tab and try using a longer latency time setting.
If you still have problems give us a full discription of your config/setup and we can try to help.
Daz
Daz
Posted Thu 18 Feb 10 @ 12:48 am
the problem was in the presets where the arrow was all the way on the 'Best Quality' side with a latency of 5ms, so i just slid the arrow a little to the left which increased the latency to 11ms. problem solved. thank you!
Posted Thu 18 Feb 10 @ 5:06 pm
