Instead of purchasing VDJ Basic via download, how do I purchase it via postal delivery? The Pro provides the option, but I can't seem to find the choice on the Basic.
Posted Tue 16 Feb 10 @ 10:03 pm
The only way is buy it and download it from here. Is more easy.
Posted Tue 16 Feb 10 @ 10:22 pm
VirtualDJ Basic is only available by download.
If you want a CD for backup, then once you have made the purchase and downloaded the file. Then burn it to a CD - it would be the same as if you received a CD burned from us.
Also, remember; once you register your software serial then you will always be able to download it from our site in the Download Center.
Posted Tue 16 Feb 10 @ 10:24 pm
