Hi
Am currently using the demo/trial version, and am facing a small issue with hot cues.
In the VDJScript Wiki, the "hot_cue" verb definition says that if I am in a loop, then pressing hot cue will shift the Loop In to the hot cue, but retain the loop length.
However, this is not currently working for me, and if I press the hot cue I just exit the loop.
Can someone please tell me what the problem is, and if there is a workaround for this using VDJScript? I would like the hot cues to retain the loop unless manually exited.
Thanks
Sid
Thanks
Sid
Posted Tue 16 Feb 10 @ 1:32 am
