Just wondering if any can verify the quality of sound from Numark's NS7 sound card? Is it good or is it a great sound card?
I'm using NI's Audio 4 and it's an awesome sound card. Wondering if Numark's is just as good or better? I'm asking because Numark's VV soundcard was not that great thus my reason for buying the Audio 4.
Also wondering if it's easy enough to run an external sound card like the Audio 4 with NS7?
Posted Fri 12 Feb 10 @ 9:18 am
i cannot verify the ns7 with vdj, but with serato itch, the sound card was very good. also, i have the VV box, what did you think was bad about it? i did have some times where it would mess up the channels during first boot up, but never had a problem in a gig...
Posted Fri 12 Feb 10 @ 11:26 am
Well, it's a decent sounding card but the output levels are weak compared to the Audio 4
Ideally, I want to match output levels simular to what I get over the CDJs - the Audio 4 gives me that
The VV soundcard is kind of quiet - turning up the volume results in distortion - i'm not having that problem with the Audio 4
A4 is a great soundcard
Posted Fri 12 Feb 10 @ 12:35 pm
