I'm playing with the demo version and it looks great so far but I would want to use the playlist function if using the system "live", so that played songs get removed to avoid duplicates.
BUT - how do I "freeze" the playlist frame so it doesn't automatically disapper off to the right hand side of the screen every time I move the cursor out of the playlist window?
Everything else is perfect apart from that - and it's enough to stop me buying - hopefully somebody can tell me how to lock the frame and resize it so it stays where I want it, just like the sidelist at the bottom of the screen?
Posted Thu 11 Feb 10 @ 5:36 pm
Hi there,
You'll find a small icon at the bottom of the playlist window, next to the border. Hover of this and it should have a tool tip that says 'lock panel "playlist"' or something similar.
Click on this and the playlist will remain open.
Cheers,
Roy
Cheers,
Roy
Posted Thu 11 Feb 10 @ 6:23 pm
Fantastic just what I was after. I don't think I can find any other faults and therefore now have no excuses not to buy ! Thanks :)
Posted Fri 12 Feb 10 @ 9:09 am
Remember to add your serial number to your user profile. That way you'll be able to access all the cool add-ons plus be eligable for the free lifetime upgrades!!!
Roy
Roy
Posted Tue 16 Feb 10 @ 11:32 am
