Topic: STEALTH CONTROL SETUP HELP
So I recently purchased the Numark Stealth Control and have had no problems messing around with it when connected to just my computer and a set of speakers.
I wanted to be able to cue a song in my headphones before playing it so I was advized to buy the Behringer U-Control 202. Despite all my efforts, I am not able to pick the correct configuration and have my earphones play a song without that same song coming through the main speakers.
Can anyone please help me with this problem!! Thanks so much!!!
Posted Mon 08 Feb 10 @ 1:27 pm
According to your Virtual DJ Version there are different configurations.
Which version of VDJ are you using ?
Greets, Heiko
I am using the Professional Edition Version 6. I just need to know what configuration I should use, or if the Behringer U-Control is even able to perform these actions. Should I just go ahead and buy the Numark DJ/1O? Thanks so much for you help! I really appreciate it
If you where using version 6.0 you should update. Your version is a bit outdated ;-)
Greets, Heiko
let us say that i do upgrade. Will the behringer u control still work? This is all i need to know
VDJ is backward compatible especially between the various 6.0x releases. Register your copy here (https://virtualdj.com/users/edit.html) and then you'll be able to download the latest 6.0.5.
Cheers,
Roy
Or maybe give a try with the latest trial version if at all you're still in this process.
I don't think the headphone out is separate from the main out on the U-control. Probably better off getting a soundcard made for DJing, like the DJ IO or an esi Maya 44.
