I purchased the Virtual DJ Pro 6.05 (download) recently because It said the Vestax VCI-300 was now fully supported. Here is my setup: Mac Book Pro running Snow Leapord and Vestax VCI-300 Controller. I cannot "cue" in headphones using VDJ nor is the mic thru working. Again, Controller Sound works with other DJ programs but I love my VDJ. Headphones work fine with Serato Scratch and Itch DJ programs. I am able to Monitor and Cue out of headphone jack in these programs. I have adjusted the settings in my computer (following a forum on this site). My software settings for VDJ are Main out (Rear), Headphone out (Front), 4-Out Sound Card, VCI-300. Funny thing is, if I select Main out (Front), I am able to hear (main) sound out of headphones, however no sound comes out of Main outputs. Thank You Help Please.
Posted Sun 07 Feb 10 @ 9:13 pm
Anyone? Help? I have even wrote VDJ and it has been over a week and support has not contacted me back!!
Posted Fri 12 Feb 10 @ 10:56 pm
Hey groove DJ I know this is off topic, but I was wondering what device are u using as a sound card? cuz i heard the vci is a controller and not a sound card.
Posted Sat 13 Feb 10 @ 9:07 pm
I am using the Vestax VCI-300, it is a sound card and controller. The VCI-100 is just a controller.
Posted Sat 13 Feb 10 @ 9:42 pm
why arent you using the mixer to cue with your headphones? it is much easier then trying to do it with vdj's internal one
Posted Sun 28 Feb 10 @ 3:50 pm
on the card option change the main and headphones from front to rear...should be an option for doing it in both directions main fron, or main rear-headphone front or headphone rear
Posted Sun 28 Feb 10 @ 3:53 pm
also if the microphone isnt working open itch and leave it open in the background while you use virtualdj had this problem on my ns7
Posted Mon 01 Mar 10 @ 6:15 pm
unfortunately the same trick that works on the ns7 doesn't work on the vci-300 the one I have here I've not been able to get the sound card to work properly at all I use mine with the deejay trim and just the 300 as a controller. If I find a way to make it work I'll post here about it.
Posted Mon 01 Mar 10 @ 9:34 pm
Just wondering if you got the cueing in the
headphones to work and, if so, how did you do it?
I have a MacBook Pro, VDJ 7 and a VCI-300 and
cannot cue in the headphones.
Thanks!!!
Thanks!!!
Posted Tue 28 Dec 10 @ 2:57 am
I have a IDJ3 and IMac and am having the same problems. I have headphones hooked up but cannot cue from them. I have tried to config the output option and soundcard. Any suggestions?
Posted Tue 28 Dec 10 @ 6:57 pm
ok i have the same issues i cant cue as well i either hear it from my headphones or computer why cant i get both ????
ANYONE got same issues wat to do ?????
Posted Mon 21 Feb 11 @ 7:23 pm
