Topic: No sound from headphones using cue+xponent
I have no sound from my headphones when using Cue. But sound comes out fine on vdj. Can anybody shine some light on this issue?
Posted Mon 01 Feb 10 @ 10:42 pm
anybody?
What sound card are you using? Did you select "Outputs: two" in the VDJ config/sound set up tab?
You need to select:
Inputs: None
Outputs: Headphones
Then select either 2 cards and select the two M-Audio Xponent options, or select ASIO and the M-Audio Xponent ASIO.
Thanks guys. I reallized my mistake and it now I have sound. Thanks again.
A lot of the fixes for this particular problem seem to be for older versions of vdj and I was wondering what the fixes for this would be in vdj 8? Ive tried messing around myself to fix this and tried a lot of the fixes that worked for older versions but nothing is panning out so far.
Home Users are not permitted to post email addresses.
As stated, this information is outdated. Please start a new thread on this subject.
