Does anyone know if the Denon DN-HC1000 works with VDJ? It's meant for serato and i use a denon hd2500. Love to use both.
Posted Sun 31 Jan 10 @ 12:44 pm
The definition/mapper can be downloaded here - https://virtualdj.com/addons/10428/Denon_DN-HC1000S.html
** Will only work on Vista/Windows 7/Mac -- does not use the unique device identifier required for use on the Windows XP platform
Posted Sun 31 Jan 10 @ 1:07 pm
can i use it with my denon hd2500 ,,, both at the same time? and what will it control?
Posted Sun 31 Jan 10 @ 1:15 pm
Why did I get this message "Sorry, you don't have the necessary accreditations to view this page." when I try to download this mapper?
Posted Thu 09 Sep 10 @ 1:07 pm
so this doesnt work on XP? my VDJ laptop is XP and I would like to use this controller
Posted Thu 29 Dec 11 @ 12:20 pm
Question - if I read correctly, I see that the HC1000 doesnt work on XP.. HOWEVER, I just tested on with the latest VDJ 7.X running XP HOME SP3 and the controller worked 100% fine.. why are we saying it doesnt work under XP?
Posted Fri 04 May 12 @ 8:49 am
no one going to answer? I now have one of these controllers.. I didnt download any mapper........ in fact, the mapper is no longer on the site. I am also using it with XP HOME SP3 and it is working 100%. so, is the mapper not needed??
Posted Mon 07 May 12 @ 7:00 pm
that post is almost 6 months old, maybe it wasn't working on xp due to drivers by denon not working on xp or something, mappers are built directly into the program. but if a release isn't pending a mapper and definition file will be released to patch the full version until the next release where it will be built in.
Posted Mon 07 May 12 @ 7:30 pm
