I'm experiencing a lag/delay with my controllers. I have the dac 2, dac 3, and the dennon hc4500. this happens with all of them, but the least with the dennon. Please note this doesn't happen with pcdj or serato.
To clarify the lag: any button I press, the program doesn't recognize this instantly (a fraction of a second late). Now I've seen responses to other posts makin excuses for this. If there is no delay in pcdj, there should be absolutely no delay in vdj.
I'd appreciate any advice, to change settings or whatever. Btw im pretty sure it's not my CPU, I have a pretty new system that handles the videos flawlessly.
Thanks.
Thanks.
Posted Sat 30 Jan 10 @ 6:18 pm
It's called latency, and is probably down to your configuration. In order to help we need to know:
* What sound card are you using?
* What settings do you have on the Sound Setup tab?
* What settings do you have on the Performance tab?
* If using ASIO, what latency do you have set in your soundcards control panel?
Posted Sat 30 Jan 10 @ 8:20 pm
