i am a pro user with a legal serial for vdj. i was wondering if i decided to migrate to virtual vinyl which is typically vdj, only difference is the soundcard.can holders of a legal purchased vdj get a discount to migrate to virtual vinyl
Posted Fri 29 Jan 10 @ 4:09 am
Why do you need to migrate from VDJ to VirtualVinyl??
VDJ is the most complete software you can get from Atomix/Numark. You only need to buy an external soundcard which you can use Timecode with: for example Audio 4DJ, Audio 8DJ.
Moreover, you can get the latest version if you are using VDJ while talking about Numark CUE/VirtualVinyl you can get release only if Numark will release that: at the moment Atomix released 6.0.5 while Numark is still behind setting about 6.0.3.
It's your choice now ;)
Posted Fri 29 Jan 10 @ 4:13 am
Virtual Vinyl is a pack of the software and a sound card. If you want another license of VDJ you can buy that at a discount by entering your key.
Posted Fri 29 Jan 10 @ 4:06 pm
