Last night I noticed a slight crackling on the left side of both output channels.
My system is Dell 1745
Core 2.2 Dual
8 Gigs Ram
7200 rpm Hard Drives - dual 500 gig
Integrated video with 2 gigs ram (shared)
I am using VDJ Pro (licensed) with a Echo Indigo DJx sound card.
I have done the pc optimization and have adjust the latency to auto, safe mode and overclocked unchecked and have my presents set to fastest.
THe ONLY thing that changes anything is the sound setup/asio config and then if I set the buffer size extremely high. It goes away but then my waveforms are very choppy.
Any other suggestions? I have another event today and would love to solve this issue by 5pm, est.
Many thanks!
Scott
Core 2.2 Dual
8 Gigs Ram
Many thanks!
Scott
Posted Sun 24 Jan 10 @ 8:55 am
I have also disabled all internal sound cards as well. I switched to non-asio mode for my sound card and I have the same issue.
I am 99.9% sure that this is not a VDJ problem but will test with my PCDJ to be sure.
Posted Sun 24 Jan 10 @ 9:03 am
Fixed... disabled wireless controller and sound crackling is gone.
Scott
Scott
Posted Sun 24 Jan 10 @ 9:19 am
