Hey,
I have the Serato SL1 interface and timecode vinyls. My problem comes when I begin to scratch using Virtual DJ, I get little pops or clicks in the sound that I am scratching. Now, I do not get this problem when scratching on Serato's Scratch Live program, but only with VDJ. Now, I really like VDJ better than Scratch Live and want to solve this issue. Anyone have any setting or configuration pointers/suggestions to stop hearing glitches when scratching on VDJ?
Thanks!
Thanks!
Posted Wed 13 Jan 10 @ 9:00 pm
which version are you using?
Posted Wed 13 Jan 10 @ 11:31 pm
my guess is a crack version
Posted Thu 14 Jan 10 @ 1:32 am
mostonedef wrote :
Hey,
pop/clicks happen when soundcard runs out of audio data, waiting for new ..
you need to set a higher latency...
In VDJ performance tab, choose AUTO at the latency drop down.
And if laptop, try check the overclock on.
Posted Thu 14 Jan 10 @ 1:49 am
@ norway, could you please explain to me what the latency does? and also what about if i have the overclock on with a pc?
Posted Fri 15 Jan 10 @ 1:30 pm
does it make any difference if your in absolute or relative modes?
Posted Fri 15 Jan 10 @ 2:01 pm
wah?? ah dnno?? what are those?
i need serious help here lol. is all this in the wiki
Posted Fri 15 Jan 10 @ 2:47 pm
why you just don't use the serato program then.
Posted Sun 24 Jan 10 @ 8:10 pm
