I'm currently using 2 tchnics 1200s MK2 and Hercules RMX.
Any ideas on how to reduce the latency and improve the scratch quality?
When scratching get an annoying digital sound :(
Using Serato timecodes.
Thanks.
Thanks.
Posted Tue 12 Jan 10 @ 11:26 am
You can start by optimizing your computer as described in this guide:
http://ts.hercules.com/faqs/eng/her_eng_00363.pdf
Posted Tue 12 Jan 10 @ 3:49 pm
Thanks.... this doesn't change anything... :(
Posted Wed 13 Jan 10 @ 12:14 am
Unfortunately VDJ has the worst DVS sound quality among other software (noisy digital crackling sound). It's good hearable when you scratch slowl, very slow.
It doesn't happen in Torq, Deckadance, Traktor.
Posted Sat 05 Mar 11 @ 5:32 am
That isn't right!!
I use the Audio 8 Soundcard and Serato Vinyls. Very low Latency, very good Sound, no crackling, no drop outs, nothing!
Since Version 7 is the quality absolutly high and have no difference to other products!!
So my meaning of your problems: driver or wrong setups!
Greetz
Ava
Posted Sat 05 Mar 11 @ 1:01 pm
dj_avaco wrote :
That isn't right!!
Greetz
Ava
That isn't right!!
Greetz
Ava
Gave up and using serato now, thanks for the comments.
Still using VDJ when out of the Country and no gear or as disaster recovery in the odd case of things failing.
Thanks fellas.
Posted Sat 05 Mar 11 @ 10:35 pm
