Hello, I'm brand new to djing & any helpful tips would be helpful! I just bought the hercules rmx. I have yet to buy speakers, but that will be my next purchase. My main problem is, when I play any tracks on virtual dj 6, the sound through the headphones is very grainy & with static. I also do experience some skipping. I have an HP pavilion notebook with an AMD turion X2 dual core 2.0 GHz processor and am running vista 32 bit. I just want to know what settings do I have to change to fix this??? Please help!!!
Also, I have a home theater system that I'm curious to see if I could use as speakers. I tried hooking it up to the receiver (which is also the subwoofer) but could only get sound through the sub. The rest of the speakers are hooked up to the receiver using speaker wire. Would I be able to use these? Thanks so much in advance!!!!!!
Posted Sun 03 Jan 10 @ 8:03 pm
I can't give you much info on your grainy sound question but, yes you can use a receiver to route audio to your speakers.
Posted Sun 03 Jan 10 @ 8:26 pm
