Hey people!
I just purchased a new Sennheiser headset, that was ment to work together with my Hercules Rmx Dj console, but i can't seem to make it work ?
- There is no sound in the headset?
My soundsetup is set like this:
Inputs: None
Outputs: Headphones
Soundcard(s): 2 cards
Driver 1: Built-in Outputs
Driver 2: Hercules Dj Console
Output channels: Master : First card / Headphones : Second card
The speakers is set to the computer.
I'm using Mac and everything works, except the headphones.
Pleace Help!?
Inputs: None
Outputs: Headphones
Pleace Help!?
Posted Wed 30 Dec 09 @ 7:58 am
For Sound Setup, configure as follow:
- Input : None
- Output(s): Headphone
-Soundcard: DJ Console Rmx
Using the 2 card configuration is not possible since VDJ uses the first stereo pair of each soundcard. The Headphone connector of the Rmx being assigned to the second pair (output 3/4), VDJ cannot use it.
- Input : None
Posted Wed 30 Dec 09 @ 8:15 am
I have used that setup for many months now, and it works just fine without the headset ?
Posted Wed 30 Dec 09 @ 8:27 am
Were you using other headphone ?
Posted Wed 30 Dec 09 @ 11:24 am
No thats the problem ?
Posted Wed 30 Dec 09 @ 11:55 am
So you were not actually using the Rmx soundcard (as a 2nd soundcard) since you were only using the computer's speakers.
As I said, try the configuration I mentionned earlier and you'll see that your headphone will work.
Now, if you absolutely want to use your computer speakers ( I would recommend others but...) you can always try this:
- Run VDJ with the RMX as the only soundcard
- Connect the OUTPUT 1/2 of the Rmx to the LINE IN of your computer
- Download LINE IN from this site:
http://www.rogueamoeba.com/freebies/
- Configure it so that it uses the BUILD -IN as INPUT and OUTPUT, then click PASS THRU.
You should now be able to hear your main mix out of your computer's speakers and preview on the headphone.
Posted Wed 30 Dec 09 @ 12:35 pm
my friend phacho i read directions
<<For Sound Setup, configure as follow:
- Input : None
-Soundcard: DJ Console Rmx >>
and when i press aply the system says that there is an: eror in the asio sound driver.
--ps:a have made the update to my driver
- Input : None
Posted Sat 23 Jan 10 @ 5:07 am
