At the moment I am on Total Control + DJiO ...but would like to change it...
Couldn't really decide what to do... Which one would give a better performance? Thanks...
Posted Sun 27 Dec 09 @ 5:22 am
anyone tried both? thanks...
Posted Sun 27 Dec 09 @ 11:26 am
The only difference between the Omni and the Stealth is sound card. If you own a DJ i/o grab a Stealth and save a hundred dollars.
Posted Sun 27 Dec 09 @ 11:27 am
when you connect omni don't you just use one usb? if so, it is just like bcd2000 which i used before...is that a good thing or a bad thing...i mean using seperate sound card and controller or using one device for both?
its not about the money as i could just sell DjiO too...i just want to get the better one of two...=))
thanks...
thanks...
Posted Sun 27 Dec 09 @ 11:58 am
Yes, just one USB connection. Otherwise they are identical, minus the sound card...
Posted Sun 27 Dec 09 @ 12:21 pm
as a sound card is the internal sound card that comes with Omni Control any better than DjiO? Or is Djio the better one? I need to get this sorted and ordered today as i need it before new years...thanks...
Posted Sun 27 Dec 09 @ 12:40 pm
Same basic card...
Posted Sun 27 Dec 09 @ 1:19 pm
