If you are going to use the Decks with software, Just get the CDJ 900. The CDJ 900 and the 2000 make a difference when you are using them with just CD's.
Posted Thu 09 Dec 10 @ 6:07 pm
Im using cdj-900 with virtual dj, why my slip mode doesnt work when im on Pc mode? Please help me to fix this...
Posted Sat 12 Feb 11 @ 3:14 pm
Hi,
I'm trying to configure my CDJ900's with VDJ Pro 7 as MIDI controllers but am having a real problem.
I've played around with all the sound settings trying every which way but to no avail.
The problem I have, is both CDJs play on one channel and not their own.
So instead of CDJ 1 playing on channel 1 (deck A) and CDJ 2 on channel 2 (Deck B),
BOTH are playing on ONE channel.
(I'm also encountering the exact same problem when using MixVibes (sorry for mentioning that here)).
It works fine with Trakor, speaking of which, Traktor asks on startup to turn encoder (CDJ knob) for corresponding deck.
So CDJ 1 = deck A, CDJ 2 = deck 2.
I'm using Win7.
Cheers for any help.
I'm using Win7.
Posted Wed 03 Aug 11 @ 9:13 am
czakhia wrote :
Hello VDJ Staff
Please help me out. I need a document listing settings on VDJ to work with two CDJ 900's.
Actually both channels end up on the same mixer channel instead of two
Thanks
Setup
CDJ-900 x2
DJM-800 x1
VDJ 7.1.0
Windows 7 64-bit
Thanks
Setup
CDJ-900 x2
DJM-800 x1
VDJ 7.1.0
Windows 7 64-bit
type cdj 900 vs virtual dj on youtube there is a good movie how to do it
Posted Tue 26 Nov 13 @ 1:55 pm
