I recently had to buy a new laptop. I downloaded the new pro 6 but it has so many problems. I try to go back to 5.2 and everytime I install it I open the software and it says the skin is the wrong size. It messes up my screen. my resolution is 1366 x 768. I have a asus g60x.
SPECIFICATIONS
Processor-Intel® Core™2 DuoProcessor Speed2.13GHzBattery Type-6-cell lithium-ionDisplay TypeLED-backlit high-definition widescreen (1366 x 768)Screen Size (Measured Diagonally)16"System Bus1066MHzCache Memory3MB on die Level 2System Memory (RAM)4GBType of Memory (RAM)DDR2Hard Drive TypeSATA (7200 rpm)Computer Hard Drive Size320GBOptical DriveDouble-layer DVD±RW/CD-RWOptical Drive SpeedsDrive speeds not specifiedDirect-Disc LabelingNoDigital Media Reader or SlotsYes, digital media card readerGraphicsNVIDIA GeForce GTX 260MVideo Memory1GB DDR3 VRAM
WHat can I do to fix this? I had this same laptop with everythig set on it before and never had this problem.
SPECIFICATIONS
Posted Sat 19 Dec 09 @ 11:02 am
A friend of mine has the same problem. That is an odd screen resolution. He just uses the Mixlab skin and deals with lots of extra area around VDJ when its running.
Posted Sat 19 Dec 09 @ 11:16 am
I tried a skin at my resolution and it says the same thing on load everytime. also does anyone know how I can uninstall everything from vdj and reinstall it fressh? I uninstall vdj and and delete vdj from my documents but when I reinstall it saves all the previous settings. I just wanna maybe start from scratch and see if I mighta messed up a setting. I had the same exact computer before anddid not have this problem.
Posted Sat 19 Dec 09 @ 11:35 am
k got the resolution thing fixed. now onto the other probs
Posted Sat 19 Dec 09 @ 3:00 pm
