I must be going out of my mind....I could have swore that I saw a KARAOKE "button" on the VDJ which filters out the main vocals on a song. After scouring the manual and my software, it's not there. BUT...does anyone know if a plugin or other feature exists where I can filter out the vocals to make the track an instrumental?
In the Effects section I see the VOCAL option where I can filter out the music and leave the vocals. I want it the other way around!
Posted Fri 18 Dec 09 @ 6:43 pm
There is a default plugin installed called vocals+. Clicking on this plugin will give you the option to remove vocals or vice-versa. It's far from perfect though.
Posted Fri 18 Dec 09 @ 11:22 pm
This is a very difficult task for a computer to do. It would be better to get the instrumental version of the song, or the proper Karaoke version (MP3+G) which also has on-screen lyrics.
Posted Sat 19 Dec 09 @ 1:02 pm
Hi DJ Randy L
Not all songs are available in instrumental or karaoke, so that would be the next best thing to do, or hire a group of musicians and go to a recording studio and spend Big $$$$.00.
Here's a software that may help you and is design for this task. Link: http://www.mtu.com/upgrades/vogone.htm
Good Luck
Joey....
Posted Sat 19 Dec 09 @ 1:36 pm
This is a little bit of a stretch but I've done it once with an Older song (from the 1920's)
I bought a copy of the song's sheet music, and programmed it into a Step-sequencing program (fruity loops) and then exported it to an MP3 file.
Granted that only works for certain songs - but musicians do it all the time when learning to play a song by Ear.
Posted Sun 20 Dec 09 @ 6:04 pm
Hey DJ Marcel_1
You're epsolutely correct, I have Acid pro 7 and Abelton Live to do it with but, most people don't have the software or the time so they look for a quick solution to accomplish this, not 100% obtainalble but maybe close enough to do the trick.
Joey...
Joey...
Posted Mon 21 Dec 09 @ 12:20 pm
I'm italian and i have brough VDJ6pro, but i click on vocal+, but how i can delete the vocals??? excuse me for my english....
Posted Mon 22 Mar 10 @ 11:37 am
This is a very difficult task for a computer because it's difficult for it to distinguish between what is vocals and high instrument sounds.
For the best results and highest quality, you should ideally obtain the separate instrumental and acapella versions of the song. These are available from DJ services such as PromoOnly.
Posted Mon 22 Mar 10 @ 2:16 pm
