32 Bit Windows Vista - SP2:
When moving any sliders I get a lot of glitching in the audio.
Mixlab 3.1 is the skin, I'm using an M-Audio 2496 PCI as my audio interface. I had a PreSonus FP10 in the past but that did the same thing.
Anyone have any fix for this?
Thanks
Thanks
Posted Mon 14 Dec 09 @ 3:09 am
For me it sounds like a problem with your soundcard or preferences.
Try this adjustment.
If this doesn't work, maybe your soundcard isn't built for it ;)
config/performance
Presets > fastest
latency > auto
savemode and/or overclock > disabled
scratch > Quality & Simple Algorithm
48-44 > basic interpolation
mastertempo > Fast
Haui
config/performance
Presets > fastest
latency > auto
mastertempo > Fast
Haui
Posted Mon 14 Dec 09 @ 4:11 am
Thing is it's happening on 3 different sound cards I've tried...so IMO, that rules out the sound card.
Either way, I'll try what you suggested.
Posted Wed 16 Dec 09 @ 7:48 pm
Have you looked at the ASIO settings for your soundcard ?
If the ASIO buffer size is too high or too low, you could get these sorts of results.
Also, have you tried updating to the latest update 6.04 ?
Posted Thu 17 Dec 09 @ 6:55 am
