hi ive just got a samsung notebook nc10
specs:
intel (R) Atom (tm)
CPU N270 @ 1.6 ghz
1.6 GHZ , 0.99 GB of ram
i want to buy a hercules rmx , just wondering if with this notebook (small computer) wether it will all work properly ?
any1 help appreciated .
thank you
specs:
intel (R) Atom (tm)
CPU N270 @ 1.6 ghz
thank you
Posted Sat 05 Dec 09 @ 2:17 pm
I have the NC20 which is just a larger version of the one you have.
It maxes the CPU when loading a song but doesn't cause any problems. Works great for audio but no use for video.
I use the Denon HC-4500 controller on Asio and the latency is great. No problems whatsoever.
Posted Sun 06 Dec 09 @ 1:08 pm
ok great :) thanks for that
Posted Sun 06 Dec 09 @ 4:45 pm
I have a samsung laptop and have used the rmx with itf for the past 6 months no problems at all regarding sound or video.....Handles both smooth as running vista
Posted Mon 07 Dec 09 @ 7:30 am
