sirwesley wrote :
Does the NS7 work with Serato Itch still?
DJElite3 wrote :
...As far as tweaks they are the same as the ones recommended for running Serato ITCH on Windows Vista 32-bit. Please help as I am becoming increasingly frustrated.
Yes its working fine with ITCH.
Posted Fri 29 Jan 10 @ 1:02 pm
I have come to the conclusion that Numark and Virtual dj have released a product that was not ready to be released... I have been Numark user for years and a Virtual DJ/Cue user since it's biginning and love their product. Untill Now. I think they have realy jumped the shark this time. I have been sitting here with an NS7 for 6 weeks and it still doesn't work. I have tried 4 diferent computers that are all at or above the minimal standards for operation and I am still dead in the water... Not to mention the Mic/Line in feature that they admit doesn't work. I am thinking class action law suit. After buying a custome raod case, a new laptop, hdmi to S-video converter, Ect... I am $3200.00 in the hole with no salotions to the problems. I have givin up. Someone had better fix these isues fast of i'll be making other phone calls then to tech support.
Posted Mon 29 Mar 10 @ 1:20 pm
Im using NS7 with VR DJ.. all the buttons is working as far as iv tested.. everything lights up..
but...
im getting some wierd noises in the music.. like.. if u turn the pitch up and down. It sound like the music slows down and then pick up speed again.
I first tryed it on my laptop but that was even worse there so i suspected it could be hardware problem, to slow computer. Tho i now try on my "main" computer. It should be good enough as i run all my games on it..
I got safemode and overclock off..
Annyone have had the same problem?
The cpu meter isnt in top so...
Hope annyone can help me out.
but...
Posted Wed 05 May 10 @ 8:38 am
I had way too miny problems using my NS7 on any PC at all, so I went with a MacBook PRo and I as of last weekend, logged my 50th show with the NSz, and my Mac has froze once, only once!, about 3 weeks ago, and that was it!
For what is is worth, I got the best performance wunning XP Pro, with settings to best performance, and a USB Maya 44 sound card. That was with 6.0.5, so at least I got it running a little better then. Hope it works out for you, I liove my NS7!
Posted Wed 12 May 10 @ 9:21 am
Hello,
Only VirtualDJ Pro 6.0.8 fix NS7 issues. So if you are trying VirtualDJ for PC you should be testing VirtualDJ Trial 6.0.8. If not, download it and try.
About Mac, NS7 works very good using Mac OS 10.5.8 and also VirtualDJ Pro 6.0.8.
Posted Thu 13 May 10 @ 11:48 am
Hello I'm Having problems with the NS7s and the Virtual Vinyl 6.0.7. Everything seems to work fine with it, exept that when the platter spins, It creates the pitch and tempo of the song to go up and down at random times. The problem seems to be fixed when I take off the platter motor off, but when I do that I can't scratch. Can anyone please help me. I currently use them on a Asus 64 Bit Windows Vista Laptop, But can also use them on a Windows 7 64 bit Laptop.
Posted Mon 24 May 10 @ 3:13 pm
try updating to 6.0.8.
Posted Mon 24 May 10 @ 3:31 pm
