Hello good people of VDJ,
I was wondering if anyone knows if it is possible to set the 1 - 6 buttons that are on either side of the RMX so that they play all 12 samples from VDJ vs playing the same 6 on either side?
Any help will be much appreciated.
Thanks alot!
Thanks alot!
Posted Tue 01 Dec 09 @ 10:35 pm
Hello,
Not the expert others may be ..perhaps they will chime in. But the 1- 6 buttons can at least with effects have different ones on each deck side. I have it set this for mine when using. Not really sure of using them for samples as I have not tried that but will go the lab and see what happens.
Hope it helps
Hope it helps
Posted Sun 06 Dec 09 @ 12:21 pm
