ok everyone i have indigo dj soundcard and a gemini 2 ch mixer and 2 turntables and vdj i want 2 hook it all up......... really i what to control my mps3 in vdj through my sound card i also have a numark total control!!!!!! i play house, rap, r&b can someone point me the write way asap pssss i love every thing u guys do thanks
Posted Mon 30 Nov 09 @ 6:52 pm
Hi mate
Sorry to answer a question with a question. Do you want to use your turntables to control VDJ through the sound card via VDJ with timecode vinyl? Or do you want to use the turntables seperately?
Daz
Daz
Posted Mon 30 Nov 09 @ 10:30 pm
I know that you can use your indigo as the primary soundcard. You can assign the output as the headphone out and the other out as the main. Since you have the total control, you can control your mp3s with this. As far as controlling wit your turntables, you would need a 4 in 4 0ut sound card. I dont know if they make just a 4 in. If you can assign both outputs to stereo at the same level from each deck in VDJ(found in settings/config>sound setup+the software provided with the indigo), you can use your mixer.To do this you need 2 stereo to mini y cable. You still wont have inputs to send the timecode signal to the program.
Posted Tue 01 Dec 09 @ 1:11 am
