Okay. Check this out. The timecode engine, was it changed internally or is there an option to change it back to v4? It works perfect for me but I catch post asking this question. In the wiki it says v4 added so Im thinking internally. Am I right? Please answer before you lock this.
Posted Wed 25 Nov 09 @ 10:58 pm
You have options with the time code engine but 5 works betters than 4 in 6.0.3.
Posted Thu 26 Nov 09 @ 12:40 am
Prociate that. Just tryna get it right.
Posted Thu 26 Nov 09 @ 1:28 am
If using the v4 engine, remember to turn ClearSound on, in the debug view.
A guide for timecode setup here
https://virtualdj.com/wiki/Timecode%20Config.html
Posted Thu 26 Nov 09 @ 6:40 am
Thanks D_I_N. I was trying to help out Rob. I didnt want to be wrong. v5 works great for me.
Posted Thu 26 Nov 09 @ 7:56 am
Even with the clearsound on, still sounds bad. Wish they fix this on the next update, its perfect on 5.2
Posted Thu 26 Nov 09 @ 4:17 pm
We are looking into the v4.
But engine 5 is better... does that work for you?
And even better the noisemap engine (use Serato vinyls)
Why dont you use those engines?
Do they not work perfect for you?
Posted Fri 27 Nov 09 @ 6:23 am
