Hi guys
i'm hookinng up bcd 3000 with Vdj on a macbook pro and i can't get the headphones to work.
I looked at all configurations... no luck
Headphones do work with traktor 3 le
I did download the BCD mapper
hope you guys can help me out. i did look through the forums but can't find any answers
cheers
cheers
Posted Tue 17 Nov 09 @ 10:16 pm
Hi mate
Can you post the details on your config. Especialy how you have the sound card side set up.
The BCD 2000 and 3000 work as multi channel cards (4 channel to be exact) the first 2 are the main out LR and the second pair LR to provide the headphone feed.
cheers
Daz
cheers
Daz
Posted Wed 18 Nov 09 @ 4:43 pm
Got it!
Cheers for the reply. I just needed a break from it. This morning with fresh eyes it all happened.
It was indeed the soundcard configurations:
It should be:
Output: Headphones -- master =front / Headphones = back
Soundcard: 4 way card -- Bcd 3000
And it all works beautiful now...
Cheers
It should be:
Cheers
Posted Wed 18 Nov 09 @ 8:11 pm
Hi mate
Glad to hear that you are up and runnin.
Daz
Daz
Posted Thu 19 Nov 09 @ 3:19 am
It should be:
How do you do this?
I've got the same problem but can't find the right configuration. How tot put Headphones and Master in front and only headphones on back.
It should be:
How do you do this?
Posted Wed 13 Jan 10 @ 3:14 pm
got the same problem.
can someone explain how to fix that please?
Posted Fri 06 Aug 10 @ 9:15 pm
