hi i am new to the dj /karaoke buisness have just purchesed vitual dj and so far have already had some pre installed songs videos and karaoke songs already on it. could someone please help me with the best sites for recent updates on songs music videos high quality and new karaoke songs . plus the the correct way to upload them to my data base . i have currently got everything on a external hardrive . any help information will be most gratefully recieced guys a novice virgin beginning hopefully dj karaoke person . ta paul
Posted Fri 13 Nov 09 @ 8:48 am
Hi mate
I use selectatrack.com for karaoke downloads they have a great range of stuff ie Sunfly range.
Just make a folder and save your downloaded tracks in the folder. The folder will show next time you start VDJ then when you click on the folder it will be added to the database by VDJ.
Remember to register your licence for free updates.
Good luck mate
Daz
Good luck mate
Daz
Posted Fri 13 Nov 09 @ 9:18 am
sorry i forgot to mention i have hucules rmx controller and virtual dj need that echo effect what do i do to get effect thanks patrick.
Posted Fri 15 Jan 10 @ 11:04 am
are these 2 guys the same person???
one has a question and the other has an rmx??? confused???
Posted Fri 15 Jan 10 @ 4:11 pm
ones from the UK the second from the States.
Posted Fri 15 Jan 10 @ 5:00 pm
