I saw the features and they said ADDED TIMECODE ENGINE v4?!!!
Does this mean the v5 engine is replaced with the v4 engine, or you can select it from the config? If this is true I'm going to buy VDJ VERY SOON!
Thanks! I'm just really excited right now!!
Posted Wed 11 Nov 09 @ 7:04 pm
You can select either.
Posted Wed 11 Nov 09 @ 7:31 pm
SICKKKKKK!!!!!!! But the problem is I seen another thread that says the the v4 engine is worse than the v5 engine in 6.0.3
Is there a way to fix that so that we can get the less latency possible
Thanks
Thanks
Posted Wed 11 Nov 09 @ 7:41 pm
The latency you can run is entirely down to your system...
Posted Wed 11 Nov 09 @ 7:51 pm
But it is still in the software too. Is there any settings we can use to make sure we get the best latency?
Posted Wed 11 Nov 09 @ 8:33 pm
