Check this out if you want to get into timecodes
http://www.hercules.com/uk/DJ-Music/bdd/p/119/deejay-trim-4-6-scratch-starter-kit/
Nice one Hercules and Atomix!!!!!!
Posted Tue 10 Nov 09 @ 12:03 pm
is the site down at the moment? i tried your link and tried going to hercules.com.
Posted Tue 10 Nov 09 @ 1:31 pm
http://www.djforums.com/content/2009/11/03/hercules-announces-a-special-deejay-trim-46-scratch-starter-kit/
http://www.gearjunkies.com/news_info.php?news_id=4431
http://www.loopygadgets.com/hercules-deejay-trim-46-scratch-starter-kit/
http://news.harmony-central.com/Product-news/Hercules-Announces-a-Special-DeeJay-Trim-4-6-Scratch-Starter-Kit
etc etc
seems Hercules have been sending out their press release ;)
NEW YORK, NY – (November 3, 2009) – Hercules, the computer DJ entertainment specialist, unveils the DeeJay Trim 4&6 + Scratch Starter Kit, a timecode DJ mixing kit. This kit is the perfect solution for DJs who want to get started mixing with timecoded records and CDs, and DJs already mixing on their computer who already own vinyl turntables or scratch-capable CD players. Combined with the DeeJay Trim 4&6 audio interface (debuted last summer) this new package will bring your DJing skills to the next level.
The Deejay Trim 4&6 + Scratch Starter Kit
The Deejay Trim 4&6 + Scratch Starter Kit is a complete solution allowing users to mix with timecoded vinyl records and CDs. The Deejay Trim 4&6 audio interface includes the new VirtualDJ® 6 LE Timecode software, along with 2 timecoded vinyl records + 2 timecoded CDs, and a set of cables to connect vinyl turntables and scratch-capable CD players to the audio interface.
The Deejay Trim 4&6 + Scratch starter kit allows DJs to use their analog mixer and 2 vinyl turntables or 2 CD players (featuring jog wheels that can be used for scratching) to control the mixing of music files stored on their computer. The VirtualDJ 6 LE TC software reproduces the actions made by DJs using their vinyl records or CDs, and applies the actions in real time to their digital music files which allows the DJ to control music track and speed playback as well as the position in the track.
etc etc
Posted Tue 10 Nov 09 @ 1:40 pm
It look great;)
Seem like an alternative package apart from numark virtual vinyl, more options now..hehe;)
Posted Tue 10 Nov 09 @ 2:35 pm
hmmmm so if i wanna downsize my RMX..that would be an option...at least its smaller and has the interface look.
Posted Tue 10 Nov 09 @ 4:15 pm
doesnt seem the starter kit is avail. but the interface single is...
Posted Tue 10 Nov 09 @ 4:29 pm
The version of VDJ that comes with it, is a limited version, that is for timecode use "only"
For you pro version users, you already have all that, and more :)
So if you already have VDJ, you might just buy the interface alone, and not the kit.
But if you also want the vinyls and CDs, the package is a nice deal :)
The package includes this :
USB audio interface for PC/Mac, with 2 modes:
- 4-channel in/4-channel out; or
- 2-channel in/6-channel out
+ built-in 3 port USB 2.0 hub
+ power adapter
VirtualDJ 6 LE Timecode software
+ 2 timecoded vinyl records
+ 2 timecoded CDs
+ 2 audio cables
+ power adapter
+ 2 timecoded CDs
+ 2 audio cables
Posted Tue 10 Nov 09 @ 5:17 pm
The DeeJay Trim 4&6 separately is available for the suggested retail price $249.95 and combined with the Scratch Start Kit will be available starting mid-December, 2009 for the suggested retail price $299.95.
Very good price :)
Very good price :)
Posted Wed 11 Nov 09 @ 8:18 am
Hercules has been designing good stuff that usually works very well with VDJ for a long time.
Hopefully this will work as well.
It's a good idea
It's a good idea
Posted Wed 11 Nov 09 @ 8:25 am
Couple questions... I'm new to this and I'm getting so many differnent answers. Its all too confusing.
I want to use timecode.
I found a deal on some old equipment and I'm not sure how to set it up with timecode. Some people say it's possible, others say it isn't possible. Throw me a bone somebody.
What's the difference between this and something like the Maya 44?
I have Virtual DJ Pro.
I may buy this used setup of (2) Axis 8 cd decks and a Matrix 3 mixer all by Numark.
I'm not a pro dj, I want to learn this and see if it's something that I like.
Posted Fri 13 Nov 09 @ 10:49 am
Does anyone know if it possible to run virtualdj version6 with deejay trim, omni controller by numark (as a mixer), and timecode vinyls. And if so where can i purchase the hardware only for the timecode?
Can you please help!
and thank you in advanced.
Posted Fri 20 Nov 09 @ 1:07 pm
from what i know and read on here..the maya 44 is a audio interface as well and works with vdj just as the herc 4 &6 will only differece is that the time code set from herc is a limited version wont be the pro, but you have the pro so its still plus value for you...which will allow you to use with the used set up your looking into getting.
Posted Fri 20 Nov 09 @ 3:46 pm
damn i have cheap buget and if the trim is everything they sayit is then damn sweet!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted Mon 15 Feb 10 @ 12:57 am
I just bought this very item and i'm having problems with the audio interface communicating with my gateway laptop with windows 7. An error message comes up and says that the interface is not connected after I uploaded the cd with the drivers. I went to Hercules.com and downloaded updates but the same error message keeps on appearing.
If the starter kit is supposed to work with the audio interface how come it will not work with my laptop. I even tried it on a computer that has windows XP pro and it shows the same error message. Does anyone else have this problem and what were your solutions? If the admins or technical support please chime in, I would greatly appreciate all helpful solutions you can provide since this is in part your product.
Thank you, Vince (DJ V-Rod)
Posted Fri 14 Jan 11 @ 8:58 pm
Hi everyone Can some one please please tell me if the (((Hercules DeeJay Trim 4 & 6 Audio Interface & VDJ timecode works with the Numark HDX turn tables.))) Every dumb a$$ wanna be deejay on youtube seems to have my kids cd player tables or are to busy acting stupid. People @ Guitar Center are clueless and if you ask VDJ they return the message years later. So I turn to you guys
Posted Sat 05 Mar 11 @ 4:42 pm
Hi guys
just a note for people who are thinking to purchase hercules dj trim 4&6 ... this kit is full of shit. it worths nothing..absolutely nothing. don't waste your money .
cheers
cheers
Posted Sat 26 Mar 11 @ 9:48 am
i need a help please ....
i bought hercules dj trim 4&6 yesterday. I installed driver as it was mentioned in manual and got my mixer and turntables connected. Now, there is no signal coming from 3/4 output and therefore i can't control deck B in VDj software by timcode-vinyl. Additionally, on the other deck where signal is 100%, the loaded song keeps moving back and forth by itself, even when turntable is stopped.... i'm so screwed. this piece of sh.. worths nothing
anybody has any clue to help me fixing such a problem
cheers
cheers
Posted Sat 26 Mar 11 @ 10:05 am
