ok, something to look into for next beta.. :) been bit of varied feedbacks on the timecode v4
Posted Tue 10 Nov 09 @ 7:56 pm
So far I am pleased. LOVE the jog mode toggle in the config and now I *MUST* retool my rig for the DAC-3.
BUT...........
Still the little snippet of track is there unless I turn either Scratch or Master Tempo quality off.
Any word yet on FLAC tags? I am retooling my library to go all FLAC next year.
Thanks for an awesome product!!!
BUT...........
Posted Tue 10 Nov 09 @ 11:08 pm
about time will try it out,still did not see a fixed for BCD3000 saw for orthers what's up with this!
Posted Tue 10 Nov 09 @ 11:27 pm
I saw a few improvements and bug fixes related to database issues, but was wondering?? Did any of these apply to the "database integrity" issues that I and many others have brought up in the recent past? i.E., virtual folders disapperaring, losing bpm data on songs randomly, songs added randomly to a virtual folder that didn't belong there, etc., etc..??
If not, please let us know??
Thank you.
Thank you.
Posted Wed 11 Nov 09 @ 12:40 am
Thanks for the gain 0 function.
Fantastic update again.
Posted Thu 12 Nov 09 @ 2:44 am
what is the gain 0 function? I have sometimes problems with autogain setting volume too low but still no ability to set more volume from the gain knob.
Also sometimes autogain sets volume too loud causing distort sound...
Anyway thanks for the update! It works very well. I got rid of random sound skips with vci-300 and asio4all.
Also now i could set better performance now with advanced master tempo on, keylock and audio buffer at 2ms!
Posted Thu 12 Nov 09 @ 8:25 am
Try to see in the list the new action "set_gain" ;)
set the gain in order to bring the song to the specified dBA (with 0dBA being the maximum level outputable by the soundcard without compression): 'set_gain 0'
Posted Thu 12 Nov 09 @ 8:59 am
Just giged yesterday night with audio and video files...no issues at all.I use vista x64sp2 audio4dj and rmx steel on lenovo3000 n200 laptop..Great update guys...thnx ATOMIX.
Posted Thu 12 Nov 09 @ 1:20 pm
exactly ;)
Posted Thu 12 Nov 09 @ 5:04 pm
No problem here..been using it for 3 hrs now testing...got a gig tonight so the real test will begain then..
Posted Thu 12 Nov 09 @ 5:25 pm
Thank you.
Thank you.
Anyone c??
Posted Thu 12 Nov 09 @ 8:22 pm
thanx guys
small "bug" though, i think ...
sort by filedate doesn't work
hope it's not just me
let me know
cheers,
matt
let me know
cheers,
matt
Posted Fri 13 Nov 09 @ 4:12 am
Sort by filedate has been disabled due to issues with it - it's in the Changelog ;)
Posted Fri 13 Nov 09 @ 4:25 am
I'm not getting my active deck waveform(top) moving to the front.
Maybe it's an issue with hardware. I'll post there too.
Posted Fri 13 Nov 09 @ 7:00 am
Well after a 4 hour gig of video and audio I had no issues..:) I did get the occasional crack and pop but that may have been due to settings? Dunno. I did notice the file date search was not working but as pointed out it was dissable for what ever reason. All in all I have to say this new version worked good for me..Now if only the back spin sounded better...lol good job guys keep it up!!
Posted Fri 13 Nov 09 @ 10:07 am
The video abilites are great.
Posted Fri 13 Nov 09 @ 2:33 pm
Virtual folders still disappear.
Oh well.
Oh well.
Posted Fri 13 Nov 09 @ 5:04 pm
Oh well.
Oh well.
I might have a solution for you on that front. Are you using external storage mediums? I noticed files in virtual folders, as well as virtual folders dissappeared for me too when my external medium with my music on it was not plugged into the system. Soon as I plugged it in, they were all back.
Posted Fri 13 Nov 09 @ 7:26 pm
Internal drives.
Posted Fri 13 Nov 09 @ 9:14 pm
bryantpb wrote :
Anyone c??
Thank you.
Thank you.
Anyone c??
Did notice abour 25+ files appreared tonight with missing BPM info after uprading to V6.0.3, without adding any new files. So, either the detection of unscanned files (or files not previously added to Search DB) improved, or the previouisly known problem(s) still exists.
I've noticed the improvements in V6.0.3, but I've more testing to do on adding files to the DB to see if the DB issues are resolved. (This is the area where I've noticed issues in the past!, I.e. <4 CD's at a time).
Posted Fri 13 Nov 09 @ 9:34 pm
