I can't get my timecodes perfect. I was using serato timecodes, thought that was the problem. so i bought virtual vinyl timecodes. Even in absolute mode, they move around.
I am using a maya44usb soundcard. I have tried everything.
If i try turning on the RIAA it seems more sensitive to the small movements of the vinyl. But then when you try cueing really fast (moving the vinyl really fast) it seems to jam up
I tried asio 4 all, playing with the settings everything.
Do i need a better soundcard? I know this one is fairly old.
One other thing i noticed is, when the vinyl is stopped, the one side seems to jiggle back and fourth a bit and sometimes will jiggle forward. I tried turning down the gain or up the silence but then it makes it even less accurate.
Posted Wed 04 Nov 09 @ 9:29 pm
maybe adjusting the needle settings from your turntable??
Posted Thu 05 Nov 09 @ 12:25 am
tried that.
Whats the soundcard everyone is using?
Posted Fri 06 Nov 09 @ 10:20 pm
try using rel mode with cue points. as well as ur normal sticker label on ur vinly...but yes even serato moves to
Posted Sun 08 Nov 09 @ 6:17 pm
whats a sticker label? my turntables came with a sticker is that what ur reffering to an if so where is it placed and why.
Posted Sun 08 Nov 09 @ 6:43 pm
a sticker as in your cue point marker
Posted Tue 10 Nov 09 @ 6:58 pm
