Help
Just hooked up the RMX to my new laptop.
Installed the latest drivers and VDJ etc.
I need to broadcast over the internet so need to use the internal soundcard. I get sound through the headphones and that's it?
Any help really appreciated.
Posted Wed 04 Nov 09 @ 3:54 am
go into sound set up mate and use inputs none.....outputs headphones...and soundcard built in(laptop).then open midi in vjd and click on rmx from dropdown box so you control software with rmx
Posted Wed 04 Nov 09 @ 7:29 am
At the moment I have it set up as:
Input: None
Outputs: Single Output
Soundcard: Simple
Obviously this allows me to play/mix live but no headphone support.
If I change to
Output: Headphones
The soundcard options change to: Mono Separated/2 cards/4.1 Card
I do not get the option to use the internal soundcard?
Input: None
Soundcard: Simple
If I change to
Output: Headphones
Posted Wed 04 Nov 09 @ 11:36 am
