Hi there.
Currently using the trial copy of VDJ6, with my friends set up maya 44 and 2 timecodes, just wondering if it's possible to use timecodes and normal vinyl, so a proper vinyl record on 1 turntable with a timecode running on the other, as i have about 200 drum and bass records, would be brilliant if i could still use those without having to unplug everything
cheers in advance.
regards
Matt
cheers in advance.
regards
Matt
Posted Mon 02 Nov 09 @ 2:51 pm
yes it can be done by using "timecode_bypass" which you can program to a keyboard shortcut in VDJ Pro.
Posted Mon 02 Nov 09 @ 2:59 pm
Thanks for the reply Dan, how is this done, via the config just asign that command to a key or what?
also is it possible to set it for which turntable i want to disable
cheers
cheers
Posted Mon 02 Nov 09 @ 3:03 pm
