I have set up numark omni with my VDJ by getting the Midi Mapper from numarks website.
One problem is that the headphones only seem to play what is being played out to the audience. Im not able to preview the next song
Posted Mon 02 Nov 09 @ 8:01 am
This is usualy a config problem and is easy to sort out.
Which version of the software are you working with?
Daz
Daz
Posted Mon 02 Nov 09 @ 8:24 am
5.2
what do i need to do? is it a case of mapping? if so, which mapping button is it?
Posted Mon 02 Nov 09 @ 9:15 am
Hi mate.
Not usualy mapping.
If you go to the config tab/Sound Setup/outputs/select/ Headphones and then set your headphones to whatever channels u use on your sound card.
As you mention mapping are you using a controller?
Remember to register your software licence ;-)
Daz
Not usualy mapping.
Daz
Posted Mon 02 Nov 09 @ 9:46 am
Yea im using the numark omni controller.
I have set it so that the outputs are speakers and headphones. however it doesnt split the headphones to what is playing to the audience
Posted Mon 02 Nov 09 @ 9:49 am
Hi, you need to make sure you are using v6 or above for best performance with this controller.
Then choose:
Inputs : none
Outputs : headphones
Card : Asio
Driver: Numark NS7
Channels 1/2 Main 3/4 Headphones
Then choose:
Inputs : none
Card : Asio
Driver: Numark NS7
Posted Wed 11 Nov 09 @ 4:29 am
i have problem with the headphone Dont listen nothing....and the three button, high, mid, bass dont work. i use them and the volumen of bass (for example) only move a quart or 90 degrees-- :-( please help me
Posted Thu 10 Feb 11 @ 11:21 pm
sorry i have numark omni controller
Posted Thu 10 Feb 11 @ 11:22 pm
Posted Thu 10 Feb 11 @ 11:23 pm
