How are you supposed to change your sound setup or go into your config? Do I need pro to do all of this?
Posted Sun 01 Nov 09 @ 11:42 am
Correct, the LE version is only designed to work with the controller it came with. You arent able to change the settings.
Posted Sun 01 Nov 09 @ 12:46 pm
