pgallotta wrote :
what is the differance between virtual dj pro and virtual vinyl
First of all its rude to hijack threads in this way. Second if you do a search you'll find loads of threads were this is discussed...
Now back to topic...
I'm gonna try and get my weekly residency to let me try video. They have 32" screens all round the walls fed from a central unit. However it looks like the inputs to this system are purely via a composite RCA connection.
We'd need a balun to get from the booth to the rack out back and ideally I'd like to have VGA input in the booth and then composite at the other end. Is this possible?
Here's the balun I'd like to get http://www.cyberselect.co.uk/product/1523. Can I get a composite B-end or should I just get a VGA to composite converter?
Cheers,
Roy
Posted Fri 06 Nov 09 @ 6:47 pm
Ok, should have Googled first... just found this http://www.startech.com/item/VGA2VID-High-Resolution-VGA-to-Composite-or-S-Video-Converter.aspx.
Anybody ever used one of these...?
Cheers,
Roy
Cheers,
Roy
Posted Fri 06 Nov 09 @ 6:56 pm
Just to put my two cents in....I run a 50 ft HDMI cable (very thick, much thicker than my old VGA cable). Whether it meets HDMI specs, don't know, don't care, no way to test. What I do know is that it works on my Samsung 42" and my DLP projector. The picture is great and much better than the VGA. By the way I use an ATI card.
Posted Mon 09 Nov 09 @ 7:40 pm
that last question made me laugh. I blew snot. Totally unexpected.
Posted Mon 09 Nov 09 @ 9:09 pm
