Hi all,
I have been trying the new VDJ6,it is a great bit of software! However, when I load a tune on to either deck it only shows the first 10 seconds or so in the waveform window, not the whole tune's waveform. Any ideas how to get VDJ to read the all of it?
Thanks...
Thanks...
Posted Fri 30 Oct 09 @ 8:13 am
Go to CONFIG -> Options and check your Max Load setting. Songs longer than this will be streamed direct from disk.
If you have plenty of memory (RAM) in your computer, you should set this to 'Always'.
Posted Fri 30 Oct 09 @ 1:39 pm
Thanks man, that's sorted it!
Happy Halloween!
Brekky
Happy Halloween!
Brekky
Posted Sat 31 Oct 09 @ 11:57 am
