Hello mates,
I've tryed but is not working. My DJ gear are: 2 x CDJ 800 MK II, 1 x DJM 600 mixer, Virtual DJ Pro 6, 1x ESI U46SE. I've tryed a lot to set up my devices working with Virtual DJ Timecodes, i had downloaded and instaled the software for the ESI U46Se, the ASIO4ALL 2.9 English Software but it's not working with the timecodes. I've made it up only with one deck timecodes. The second CDJ with the Timecode CD it's NOT working. DECK A it's working perfect with 100% timecode signal. What should I do? Please held me set up. Where did I go wrong. Thanks a lot.
Posted Fri 30 Oct 09 @ 6:07 am
Hi mate
Can you provide an explanation of exactly how you have everything connected. The fact that you have 1 of your CD players providing a good timecode signal means that you have at least got it half correct.
Daz
Daz
Posted Fri 30 Oct 09 @ 3:11 pm
Maybe you should update you version to the latest version 6.0.2. There are some bugfixes in the new version - maybe it will fix your problem.
Greets, Heiko
Greets, Heiko
Posted Fri 30 Oct 09 @ 3:16 pm
